ffs_batch files gets deleted after running
seniorante
i want to setup a realtimesync process. If i create a batch file it is working one time, but in the end of the process the ffs_batch file gets deleted automatically.
How can I change this?
therube
So are you using RealTimeSync.exe ?
If so, what is the command line (or otherwise) that you are using for it?
Or are you simply clicking (or similar) xxx.ffs_batch?
And you're saying that if you run, xxx.ffs_batch, on completion, the file xxx.ffs_batch no longer exists?
