I'm experiencing an odd issue where FFS sees files in google drive as having a modified time a few minutes newer than they really are. For instance, a file shows as modified at 10:05:23 in Finder both locally and in Drive File Stream, but FFS says it was modified at 10:09:12, or 10:11:13, etc, (in other words, not a consistent interval that the "ignore time shift" option would help with). Has anyone else experienced this, or found a solution? As a workaround I've used the file size comparison as it's fairly unlikely that a 2GB psd that's been modified would be the same size to the byte, but probably not beyond a reasonable doubt (I haven't thoroughly tested).
Any help would be much appreciated!
Files in Google Drive show different modified time
What modification time do you see when you access the file directly via the web interface?
https://drive.google.com/drive/my-drive
