I am receiving "Error Code 82" when attempting to Mirror files from a hard drive to a flash drive. Some of the files are being copied over successfully, while the majority of the files in the HD folder are triggering this error.
7:35:50 AM Error Cannot copy file
"L:\Uniform and Equal Analysis\0370580220052 (2012 U&E) 5606 Bissonnet St (APARTMENTS).xls" to
"J:\0370580220052 (2012 U&E) 5606 Bissonnet St (APARTMENTS).xls.ffs_tmp".
Error Code 82: The directory or file cannot be created. (CopyFileEx)
I've even deleted all of the files on the flash drive and started clean and I get the same errors.
See attached screenshots.
What might be causing this?
Thanks,
weg
All files not syncing - why?
The "RecycleBin.ffs_tmp" is an intermediate directory used when deletion handling is set to "recycle bin" in synchronization settings. Are you able to create this directory manually on J:\?
Yes, I can.
Zenju,
Can you not offer any other suggestions for me to try?
Not sure why this problem hasn't generated more replies.
WEG
WEG
