how do i recover Mirror Synchronization data from pendrive
vidhi
hi,
how do i recover Mirror Synchronization data from pendrive .i had made very big mistakes as i clicked mirror sync so all my source file data has deleted can i get back that data
pleace help me out
reply soon .waiting for the positive reply
It depends on the Delete Files method you selected in your FFS Synchronization Settings (F8).
If you selected Recycle Bin or Versioning, then look in the relevant location(s).
If you selected Permanent, you need to revert to dedicated file recovery tools.
