FFS11 can't sync with NAS-Folders
Heiko
under "Linux Mint 20 64-Bit" i can't sync my files from local filesystem to a folder on my NAS.
Sync from local directory to local directory works.
Local to NAS works with rsync.
With FFS11 i can look about the difference between local and NAS, but if i try to sync, FFS freeze after 1sec.
In the logfile is nothing.
Is somebody here with the same problems.
Greetings from from
Heiko
Heiko
If i install the 10.25 as Flatpack i become this message if i try to sync the folders.
I never become before this message.
Is their a switch i must use?
I will overwrite file at the nas-hdd.
The version 11 don't show this message it only freeze.
Greetings from germany
Heiko
Heiko
Nobody there how can help?
Greetings
Heiko
What happens if you disable 'fail-safe file copy'? Be careful, that option is there to prevent corruption, so don't forget about it
Heiko
the problem is the same. no changes.
Heiko
Try deleting that .ods file and syncing again. Does it fail at the same file/spot every time?
Heiko
Hey,
.ods is for LibreOffice. Where can i find the ods-file you mean?
FFS fail after one second and not on the same file.
Hmm, about a few minutes i start a new sync. A folder with files to a empty-folder. at the moment this sync is running.
I think a need a debug option to find the files that freeze ffs.
Heiko
