EIO: Input/output error [rename]
KSJ
I have issue on linux when I try to move some files from PC to Android.
I use mtp mount via gvfs as:
/run/user/1000/gvfs/mtp:host=Xiaomi_SDM636-MTP__SN%3ABC49BBF9_cfc09085/Internal shared storage/DCIM
When I copy files via file manager to Android, there is no issue.
But when I use freefilesync, some of the files are never copied.
PS: I have found it is caused by default fail-safe copy in settings. When I disable it, it seems to be ok.
