I created a job that would sync from a local folder to a network destination using FFS 11.0.
Nowhere do I see an option to supply a user name and password to connect to the network destination, so, naturally, I get an ERROR_ACCESS_DENIED when I try to perform the sync.
Where do I enter credentials to connect to the network destination? I must simply be missing it but I just don't see it in the UI anywhere.
Where do I enter network credentials to sync with a network destination?
Ugh. User error. The access denied was referencing a LOCAL hidden folder. I simply had to create a filter entry to omit this folder that I don't want to sync anyway and that solved the issue.
