I love Free File Sync (Windows 10) and customized it a long time ago to do nightly backups. I need to put the automatic backups on hold for a few days while a new computer is being built but I can no longer remember what I did! How can I:
* Pause the auto backups
* Once I have my new computer, update (e.g., backup d -> g might now be d->e
Thanks!
Temporarily putting Free File Sync on hold
Disable the RTS startup entry
xCSxXenon's reply applies when you use RTS to launch FFS.
However, if your automatic backup is a scheduled launch of FFS,
you need to delete or suspend that task in the Windows Task Scheduler.
