FFS ignores files with dots in them when syncing to Google Drive
popomus
Suppose I'm using the Update function.
On the left is local drive, on the right is Google Drive.
If on the left there is a file called something like "20.0524 parents.mp4" it is ignored and it will not sync to Google drive. If I rename the file as "200524 parents.mp4" then it will.
This does not happen if the right side is an external hard drive - it only happens with Google Drive.
Can you attach a picture(s) of the comparison window? It may be a limitation of Google Drive, as periods are frowned upon in file names.
popomus
I have no idea why, and this is maddening and bizarre, but today, after a restart, it works. Completely insane. Thanks for your reply, and I'll screenshot it if it happens again. Cheers.
