macOS Alias & Symlink
chweyd
Would it be possible, to add an option (for both source and target) wether to follow symlinks or aliases and treat them as normal folders. Currently symlinks or aliases to another folder is not resolved - the containing files are not copied only the alias itself which points still to the original drive.
Symlinks should be fully supported and working.
