Avoid Message-Screen at the end of a realtime Sync
Grobschnitt2611
Although i checked the auto close button and it is "true" in the batch, there is still a message screen at the end of realtime sync. I put the batch in my startup-folder.
How can I avoid this message screen?
You don't want the batch in the startup folder. You want to put the ffs_real in the startup folder
Grobschnitt2611
Thanks! It works!
