unresolved conflicts bug in version 11.0?
mario
Version 11.0 64bit. Possible bug when a large number (several thousands) of files/folders are added to one side. I get the usual "unresolved conflicts.. will not be synchronized" error message, but the synchronization does complete. The "both sides have changed since last sync" icon stays, even after a restart and several synchronizations.
A large number of files will result in a different message, something about the two locations being significantly different. Do you have multiple pairs with the same base folders?
mario
Thanks xCSxXenon for your reply. Yes, I received also the "significant different" message, which was an appropriate message. And no, I don't have multiple pairs with the same base folders.
Are your view filters set to show the unresolved conflicts?
mario
Yes.
