I would like to Two-Way sync between two computers, but need to use a NAS drive as a middle-man. Changes made on either computer need to be synced to the other computer.
I have set up FFS on the first system and have initiated the sync. This replicated the data to the NAS drive successfully. It also created the DB file as expected.
Now I am setting up FFS on the second computer, and wish to configure a Two-Way sync between the second computer and the same NAS folder. Will this create a different DB file? Will the existence of the DB file for the first computer prevent the proper operation of the second computer's FFS?
Is there a way to tag multiple DB files to indicate that file1 is for syncing to computer1 and file2 is for syncing to computer2?
Syncing between two systems using NAS
No need to worry. See here.
Awesome! Thank you!
