Cannot create ffs_tmp
alex
First, thank you for this amazing software !
I have a problem, I'm trying to synchronize 2 folders, the source folder is in Read-only (intended behavior). When I execute the batch fil, I have this error:
How Can I avoid this error ?
Thank you :)
The error message is clear: the user under which user credentials FFS is run does not have (write) access to the \\SPARTA\Nextcloud folder.
alex
Yes, as described in my first post, I don’t want change the read only permission of this folder.
I just want disable the top file writing.
There is a setting to disable fail-safe copying
Although, I don't think FFS makes tmp files in the source, unless you are in two-way
