Hi
I lost a lot of files. At the place of "update", I selected "miroir", By by files !!!!!!!!!
is it posssible to change each time color of Synchronisation.
For example "miroir" , color ORANGE, attention !!
synchronisation color
You would need an equally attentive color for each setting, and as the saying goes, if everything is special, nothing is. If orange is 'attention' for mirror, what should two-way be set to?
hi,
yes, for option "mirror", and may be with additional windows "are you sure to run mirror, all files wil be overwritten/removed" ??
something like "are you sure to erase your HDD"
If you look at the Compare results, the proposed actions already have a clear color indication.
If you e.g. use the Mirror variant, a right-side file that is proposed to be deleted shows an icon with a trash-can and a large red minus sign.
Conversely, files that will be added to the right-side, show an icon with an arrow and a large green plus sign.
hi
Yes, I know, but one time, I've click to synchronise and it was "too late"
PEBCAK
YES !!
