I want to synchronize between Android and PC.
I've tried using direct-connected MTP and Wi-Fi FTP, but neither of them keeps the timestamp.
Is there any other good way?
(Sorry, I used the translator.)
Connecting with android
Using MTP, my timestamps stay consistent
Did you ever make any progress on this?
I didn't sync often, so I just solved it by using SD reader.Did you ever make any progress on this? shields, 29 Jan 2022, 02:21
I recently found out that if real-time synchronization is okay, Syncthing is also a good choice.
I've been trying to sync with android over wi-fi SFTP, but the timestamps problem is awlays there. Is this SDReader an app? Do you have more details about how you solved it?I didn't sync often, so I just solved it by using SD reader.Did you ever make any progress on this? shields, 29 Jan 2022, 02:21
I recently found out that if real-time synchronization is okay, Syncthing is also a good choice. kenai, 30 Jan 2022, 03:37
