[Bug Report] Sync from Google Drive Shared Folders not working correctly
Stpham
Case: 1 Shared Folder, 2 Gmail accounts A and B
When A sync file Test.txt from A-PC to Shared Folder on Google Drive then B tries to sync from Shared Folder to B-PC, nothing showing, that means can't sync file Test.txt to B-PC. But when I try to create a new folder at A-PC then move Test.txt into the folder then sync to Shared Folder on Google Drive, on B-PC it shows up on FFS and can sync both New Folder and Test.txt file to B-PC
What are your filter settings?
Stpham
My filter settings are Default
