I have a job that runs fine when I run it in the app but when I create a batch job and run it in Windows scheduler, I get this error
Task Scheduler successfully completed task "\Sync Progressive backup" , instance "{d06e4dd3-3187-457f-8fef-bcc3a8f7d694}" , action "C:\Program Files\FreeFileSync\FreeFileSync.exe" with return code 2147942401.
Does anyone know the cause?
Thanks,
Kendall
error 2147942401
2147942401 = 0x80070001 = ERROR_INVALID_FUNCTION
Thank you. Does that mean an invalid setting in the batch script that was generated?
This error is not coming from FreeFileSync. Maybe the Task Scheduler configuration is incorrect.
