How to sync "symbolic links" in linux?
CRD
Hi there!
I've just installed FFS and it seems really great. However, I'm trying to sync two linux machines and I cannot find, for my life, a way to sync symbolic links (which I want to be identical in both machines). I always get the error message "Operation not supported between different devices."
I've ticked "Direct" in "Include symbolic links" in the Synchronizing Settings.
Can someone, please, advice? Many thanks!
What is the full error message?
CRD
Hi Zenju,
The full message is:
Cannot copy symbolic link "sftp://server/folder/link" to "/folder/link".
Any ideas?
CRD
More details, in case it helps: I'm using FreeFileSync 11.1 on Linux Mint 20 Cinnamon...
FreeFileSync should support this. => ToDo
CRD
Thank you , Zenju!
Just for reference, in case some one else is in the same situation, I'm syncing the symbolic links in the meanwhile using rsync:
rsync -avzu -e ssh "remotehost:/path/remotesymlink" "/path/localsynmlink"
(see rsync man page for details...)
ryoushi86
Any update about this issue? I'm trying to copy symbolic links between 2 devices and the error message is :
Info : Creating symbolic link "/mnt/whatever"
Error : Cannot copy symbolink link
"sftp://mnt/whatever to /mnt/whatever".
I'm using FreeFileSync 11.5 on Debian 10 with "Direct" box ticked
Thank you for your wonderfull software !
mdrmdr
I second this request to be able to sync symbolic links from (in my case) Linux to Windows. A Linux symbolic link should result at Windows in the file the link is pointing to.
Thanks a lot!
I second this request to be able to sync symbolic links from (in my case) Linux to Windows. A Linux symbolic link should result at Windows in the file the link is pointing to. mdrmdr, 15 Jan 2021, 11:17
This should already work. See "Symbolic Link Handling": https://freefilesync.org/manual.php?topic=comparison-settings
mdrmdr
Unfortunately not. I get "Operation not supported between different devices." I included symbolic links as "direct". I use FFS 11.5 on Windows and access Linux via ftp.
Unfortunately not. I get "Operation not supported between different devices." I included symbolic links as "direct". mdrmdr, 15 Jan 2021, 12:25
So this is also SFTP => Windows?
mdrmdr
Not SFTP, standard FTP.
You need to set symlink handling to "follow".
mdrmdr
No success. Then I get many errors like
CURLE_FTP_COULDNT_RETR_FILE: RETR response: 550
550 '/opt/automation/config_links/000-default-ssl.conf' is not a directory [curl_easy_perform]
ryoushi86
Syncing symbolic links between 2 linux boxes would be very nice :)
mdrmdr
FileZilla also shows the 550 error:
Command: CWD 000-default-le-ssl.conf
Answer: 550 000-default-le-ssl.conf: Not a directory
But then it does not stop and just copies the linked file....
But then it does not stop and just copies the linked file.... mdrmdr, 15 Jan 2021, 12:51
Indeed. The FTP protocol is very limited compared to SFTP regarding symlinks but FreeFileSync might be able to do something about this => ToDo
mdrmdr
The FTP protocol is very limited compared to SFTP regarding symlinks but FreeFileSync might be able to do something about this => ToDo Zenju, 15 Jan 2021, 16:06
Implemented! FreeFileSync now handles symbolic links pointing to files via FTP (before it only supported links pointing to directories)
https://www.mediafire.com/file/o9m2m2y0c61al7w/FreeFileSync_11.6_%255BBeta%255D_Windows_Setup%25284%2529.exe
mdrmdr
Installed 11.6 Beta and still the same error "Operation not supported between different devices". German error message attached.
You still need to set symlink handling to "follow".
mdrmdr
If I set it to "follow", I get this error for each linked file:
mdrmdr
In the affected directory on my Raspberry, I have links to files and directories. I'd like to only sync the linked files, not the directories. Excluding the directories still gives the above error.
Actually I would expect the following behaviour:
• "direct": sync linked files and ignore linked directories
• "follow": sync the whole tree of a linked directory (possibly with a "depth" parameter?) and sync linked files
Therefore I'd prefer "direct" with the above behaviour or "follow" with "depth=0"
If I set it to "follow", I get this error for each linked file: mdrmdr, 16 Jan 2021, 13:06
It seems "fullchain.pem" is incorrectly considered a directory. Here's a debug version of FreeFileSync, which error details do you get?
https://www.mediafire.com/file/t7mj94453u3zbs5/FreeFileSync_11.6_%255BBeta%255D_Windows_Setup%25285%2529.exe
mdrmdr
Same "is not a directory" error during "compare" as before for any linked file with "follow". No further details. Where should I see more details?
Did you run the same test case? I've added code if the item name is "fullchain.pem" and FreeFileSync will show a different error message. Also check you're really running the correct beta and not some other version.
mdrmdr
Now, the only link to be synced is:
cert -> /etc/letsencrypt/live/dyn.xxx.de/ (link)
Within "/etc/letsencrypt/live/dyn.xxx.de/":
fullchain.pem -> ../../archive/dyn.xxx.de/fullchain450.pem (file)
This gives:
If (for debugging only):
cert -> fullchain.pem (file)
it works and FFS syncs the the path "cert -> fullchain.pem"
So it seems that FFS only is able to follow 1 level?
if (for debugging only):
fullchain.pem -> /etc/letsencrypt/live/dyn.xxx.de/fullchain.pem (file)
I get:
mdrmdr
Upate: Now the attachments of the above post are correct...
(There seems to be an attachment inlining problem at your board. The second picture after "I get" should be
FFS4 not FFS3 again...)
mdrmdr
But again: My standard case is to follow links down just by one level to exactly one file. If a link points to a directory, the danger under Linux is, that a huge tree is affected. Therefore I'd exclude links to directories and only let FFS sync links which directly points to a file. For the above debugging example, I had to move some files out of "/etc/letsencrypt/live/dyn.xxx.de" so that FFS only finds "fullchain.pem".
This gives: [SIZE: 550] mdrmdr, 16 Jan 2021, 14:49
This is either:
1. an issue with the FTP server: it cannot find the file at /opt/automation/config_links/cert/fullchain.pem although it should, or...
2. /opt/automation/config_links/cert/fullchain.pem is a broken symlink
So it seems that FFS only is able to follow 1 level? mdrmdr, 16 Jan 2021, 14:49
This is FFS's new file-symlink support => okay
I get: [SIZE: 213] mdrmdr, 16 Jan 2021, 14:49
This is also FFS's new file-symlink support => okay
(the error message only comes up because it is the debug version)
mdrmdr
This is either:
Don't think so, since e.g. FileZilla has no problems following the 2 links and copying the resulting file. And e.g. "ls" shows that it's a valid link:
PI_PROD$ ls -l /opt/automation/config_links/cert/fullchain.pem
lrwxrwxrwx 1 root root 41 Jan 15 00:00 /opt/automation/config_links/cert/fullchain.pem -> ../../archive/dyn.xxx.de/fullchain450.pem
Sounds great :-) So I'll wait, until the new final 11.6 (donation) version is online.
Thanks a lot for your efforts so far and your great FFS...
This is either:
Don't think so, since e.g. FileZilla has no problems following the 2 links and copying the resulting file. And e.g. "ls" shows that it's a valid link: mdrmdr, 16 Jan 2021, 17:44
FreeFileSync issues a SIZE /opt/automation/config_links/cert/fullchain.pem which fails with 550. You can test this by manually entering this command with FileZilla. You should see the same 550 error (if not we have something interesting to investigate)
Assuming "fullchain.pem" is not broken this indicates an FTP server bug and FileZilla just got lucky to not trigger it.
mdrmdr
I wrote already, that FileZilla does see the error but continues:
Status:    Retrieving directory listing of "/etc/letsencrypt/live/dyn.xxx.de/fullchain.pem"...
Command:    CWD fullchain.pem
Response:    550 fullchain.pem: Not a directory
Error:    Failed to retrieve directory listing
Status:    Connecting to 10.0.0.10:21...
Status:    Connection established, waiting for welcome message...
Status:    Initializing TLS...
Status:    Retrieving directory listing of "/etc/letsencrypt/live/dyn.xxx.de"...
Status:    Directory listing of "/etc/letsencrypt/live/dyn.xxx.de" successful
Status:    Verifying certificate...
Status:    TLS connection established.
Status:    Server does not support non-ASCII characters.
Status:    Logged in
Status:    Starting download of /etc/letsencrypt/live/dyn.xxx.de/fullchain.pem
Status:    File transfer successful, transferred 3.761 bytes in 1 second
Status:    Logged in
mdrmdr, 16 Jan 2021, 18:01
That's not what I was talking about. FileZilla let's you enter FTP commands manually (right-click on the log window).
mdrmdr
Sorry, I did execute the FileZilla command before, but did not post it, as it also gave a 550 error:
Command: SIZE /opt/automation/config_links/cert/fullchain.pem
Response: 550 /opt/automation/config_links/cert/fullchain.pem: No such file or directory
And don't ask me why, but STAT works:
Command: STAT /opt/automation/config_links/cert/fullchain.pem
Response: 213-Status of /opt/automation/config_links/cert/fullchain.pem:
Response: 213-lrwxrwxrwx   1 root     root           41 Jan 16 16:56 /opt/automation/config_links/cert/fullchain.pem -> /opt/automation/archive/dyn.xxx.de/fullchain450.pem
Response: 213 End of status
Weird, that "/opt/automation/archive/dyn.xxx.de/fullchain450.pem" is an invalid path... FileZilla seems to combine the containing path of the 1st symlink with the resulting path the 2nd symlink. See the full path path resolution above.
mdrmdr
Found an explanation how FileZilla does it:
The directory listings returned by the server may contain information about symbolic links, though this is not covered by neither the FTP specifications nor the SFTP specifications. If FileZilla encounters a symbolic link, it first tries to treat it like a directory, and if that fails, treats it like a file. To prevent endless loops during recursive operations, symlink targets must be within the root of the operation. There is no option to control how symlinks are handled.
[https://forum.filezilla-project.org/viewtopic.php?t=30485]
and fullchain.pem is located in "/etc/letsencrypt/live/dyn.xxx.de/",
so the resolved path is
/etc/letsencrypt/archive/dyn.xxx.de/fullchain450.pem
If this is an existing file, then the SIZE FTP command should return its size, if not => FTP server bug
The STAT command seems to return successfully (213), but the shown resolved path (/opt/automation/config_links/cert/fullchain.pem) is incorrect => FTP server bug
Found an explanation how FileZilla does it: mdrmdr, 16 Jan 2021, 22:29
FreeFileSync does the reverse: it checks if the path points to a file (via SIZE) and assume a folder symlink on failure (550).
The problem with FileZilla's approach is that treating a file symlink like a folder by traversing it does not always fail. e.g. Pure-FTPd returns garbage data with success code for MLSD (e.g. "/<symlink name>" with a bogus / at the beginning of a nonexistent file at <parent path>/<symlink name>//<symlink name>)
mdrmdr
If this is an exising file, then the SIZE FTP command should return its size, if not => FTP server bugZenju, 16 Jan 2021, 23:03
Yes, this path is correct! I'll check if I can install a better/newer ftp server on my Raspberry. Currently it's the latest available ProFTPD Version 1.3.6
mdrmdr
ProFTPD v1.3.7a seems to solve it. I'll try to compile it myself... (tomorrow - it's late now :-)
mdrmdr
After having some issues with building ProFTPD V1.3.7a from source, I finally managed it. And voilà, it works with your initially provided FFS beta version. Direct links to files are now properly synced. And the size is properly shown in the Size column.
One strange thing: There is "sometimes" an issue with the link:
apache2.conf -> /etc/apache2/apache2.conf
I've to further check under what circumstances this happens, so that the problem is reproducible...
mdrmdr
I can't see a pattern. "Compare" usually works. But sometimes with 2-3 links to normal ASCII files error 550 (is not a directory) is displayed. Very strange...
If i do
size /opt/automation/config_links/apache2.conf
in FileZilla, it works now all time.
If comparison works ("usually" => not always?), then this is probably an unrelated issue. What is the full error message?
mdrmdr
It's always the same error on random 2-3 files out of 21 files in the directory containing all the symlinks. I'll try to enable a full debug log of ProFTPD and check if I can see something. It's funny, that most of the time "apache2.conf" and "crontab" shows the problem.
mdrmdr
One finding from the detailled ProFTPD logfile: For each failing file a
SIZE not allowed in ASCII mode
is in the log. Any idea?
Perfect, you found the issue! FFS needs to set "TYPE I" before "SIZE". Will see to post an update tomorrow.
mdrmdr
For both, compare and sync, what rules does FFS apply to select either ASCII or binary mode?
mdrmdr
Can confirm, that it works now. Also following (compare & sync) of a directory tree works well. Will make more tests tonight, but looks good so far :-)
Update Jan 22nd: Found no further errors. Works as expected :-)
