sftp issues permissions on new files or folders
zoushenliang
When creating a new file or folder, can the permissions set by sftp be changed to inherit the permissions of the parent folder?
Related discussion: viewtopic.php?t=7863
zoushenliang
Thank you for your response. What I'm trying to say is that if the parent directory has facl permissions, or the group in the parent directory has SGIDs set, then newly created directories and files will not inherit these features.
