Feature request : larger window size for syncing progress
cometchaserde
is it possible to make the window that shows the syncing progress larger or to store the size of the the progress window as preferences if the size was changed ?
Thanks,
Stefan
JPringle
+1. This would be great.
You are the best
cometchaserde
Hi Zenju,
I use it with Debian Stable. Is there a Beta version for Linux available ?
