Multiple Drives
fturtle
I know that with Windows I can copy files from One drive to Another and do the same from a different drive to another but don't know if FFS does the same.
What I have is multiple drives both internally and externally such as flash drives that I use for various reasons and would like to see FFS do the same as Windows using a threaded model. Don't know if it's possible but for those of us who use multiple drives as I do, it makes sense to speed things up.
FFS does not process in parallel, with exception to some NAS setups. You can define multiple source/destination pairs though and have it run them all with one click.
fturtle
Noticed that but would like to see it added as a feature if possible or is it simpler to run multiple copies and have each one work on a specific drive?
That is the current solution.
See here for more info: viewtopic.php?t=7636&p=26244&hilit=thread#p26244
