hello, I have a problem
when I connect my flash disk, FFS automatically starts the batchrun files, but 4 or 5 (i don't remember how many) tabs or progress tab that says scanning appear and after 1 tab has finished the progress, the other 3 or 4 tabs also says complete. I've made 3 or 4 command files before, but I deleted them. I think that maybe I didn't delete the command files correctly so they are still in my pc, and when I connect my flash disk, all of the commands start running the same task. how to delete the remaining command, so that I only have 1 progress bar tab?
multiple progress dialog appears for just one batch run file only
Depends how you set it up originally. Check your startup locations
