I want to sync my google drive with my computer. And I want to exclude a special folder located in my drive from syncing. What can I do to simply exclude that file or folder always?
I don't want to select all the other files and folders one by one.
How to ignore a Folder while syncing?
Did you try using the Exclude Filter?
An easy way to do this is run the compare, then right-click the folder/files, then click exclude from the context menu
