Just started using FreeFileSync. Running 6 different folders backing up from computer to NAS to Windows Storage Spaces.
One run gave me an error message because a file could not be overwritten. Solved this by rebooting the computer. Yet, I still get the error message.
4 of the runs got me warnings regarding recycle bins. Got rid of the recycle bins but still get the warnings.
I'm sure there's an easy way to remove these errors and warnings after the underlying problems have be fixed, but I can't figure out how. Any help?
Removing errors and warnings
Never mind. Apparently you have to close the program, restart it and run the compare and sync again. As I had run the compare and sync many times without removing the errors or warnings, the key is to shut down and restart the program.
