Installation files are corrupted
marcoqf
Today i got an error message
Installation files are corrupted. Please reinstall
Installation was registered on a different operation system.
im not sure but it can be my disk upgrade.
Some days ago i just upgrade my ssd disk from 250 to 500 gb.
As migration program i use Samsung migration.
At this point all other programs are ok, only freefilesync is not opening.
Sonik_C
Just re-run the FreeFileSync installer and it will fix the issue. I had the same issue when I cloned my HDD over to an SSD. The installer will repair those files.
marcoqf
i re-install FreeFileSync and now is working
streik
But the next day or after a few days, for example 5 days, it happens again. And now it happens to me every day. And I have to reinstall the program every day. That's not a plan. It takes away all credibility. And it's a shame, because the program works well. But then you have to reinstall it every day. Any positive solution?
But the next day or after a few days, for example 5 days, it happens again. And now it happens to me every day. And I have to reinstall the program every day. That's not a plan. It takes away all credibility. And it's a shame, because the program works well. But then you have to reinstall it every day. Any positive solution? streik, 17 Sep 2024, 20:52
Your issue is not relevant to this topic, you have something else going on in your system.
