One fileshare, two sources
kmagkos
Hi forum,
I have two workstations and one remote fileshare. I would like to schedule a 2-way sync between each workstation and the fileshare. I' m using FreeFileSync 11.2.
Would that be possible considering the use of a common sync db file? Is there a way to use different sync db files for each sync relationship?
Thank you!
Just set it up normally. I have the same setup for a couple stations and there is nothing special required.
kmagkos
Great!
Thank you all!
