[https://translate.google.com]
When I try to rename a sync with the right mouse button on the last sync I get an error
Rename a sync
- Captura de pantalla (25).png (293.46 KiB) Viewed 540 times
Renaming a sync effectively means: renaming the filename under which that sync was stored.
As the Last Session (Ultima sesion) is an FFS system name and not an actual file name, it can not be renamed. You can simply save the Last Session under any name desired by using the floppy-icons just above.
But it would be more elegant if the Rename option would be grayed out for the Last Session configuration, instead of first offering the Rename option and then give the error message.
Good idea! Changed for the next version.But it would be more elegant if the Rename option would be grayed out for the Last Session configuration, instead of first offering the Rename option and then give the error message. Plerry, 30 Oct 2020, 09:00
