Error_DIRECTORY: Invalid filename
luemar
I woud like to synchronize my outlook calendar data on my notebook with my PC, PC (left) to notebook (right).
My .ost file on my PC can be accessed properly in the left window. However for the right window selection
I only get to the appropriate folder (C:\users\myUsername\AppData\Local\Microsoft\Outlook) but the .ost file
is not listed and I get an error saying that the pad could not be found or the folder can't be opened
I have released all involved folders for access.
You don't access files when choosing your left/right locations. You have to choose the folders that you want to sync. For you, you will have to choose the folder where your .ost is stored, then change the filter settings for the sync. You will want to change the include filter from '*' to probably "*.ost"
