Can't Return to my Previous Screen Layout
Stevekir
Please see the two attached clips of my FFS screen (I’m on Version 11.3 now but have used many earlier versions). The attached "Previous" screenshot shows how FFS used to look like, for years. Suddenly, it changed recently to "Current" which no longer has a lot of the info that I need, especially the list of past backups on the left and the two separate buttons at the top: "Compare" and "Synchronize". The two separate buttons allowed me to carry out these two operations separately and in order.
I have search Everywhere but cannot find any way to get these features back. How can I do that please?
Thanks, Steve K. foreverk1579@gmail.com
Did you try?
Tools > Show "Configuration"
or
Tools > Reset Layout
Stevekir
Did you try?
or
Tools > Reset Layout Plerry, 05 Nov 2020, 12:46
I don't have "tools > Show configuration" on my FFS (current version ). I didn't want to use "Tools > Reset Layout" in case it did somethig I didn't want. However, it solved my problem and I was then able to use its Save button to regain the list, at the left, of my set up routines. Many thanks.
