NVIDIA
john78
FreeFileSync worked correctly. Now (even after re-installing) FFS refuses to open and gives an error message. see Attachment.
The nVidia graphic card says the latest driver is installed.
What can do I to use FFS ?
Many Thanks for your help.
Wagner
This happened to me after the Windows 10 update (1909 64bit).
The solution was to reinstall the driver, installation "clean", according to the installer.
