New features proposal
yuri
I use FFS sometimes and would like to suggest 2 evolution.
Instead of create a FFS for each project separately, I prefer to create one FFS global configuration for multiple project. Then I can synchronize all my project simultaneously once a day for example. In this case, when you have numbers of synchronized pairs of folders, It could be very useful to be able to:
1) When you create a exclusion filter, be able to create this filter only for the pair of folder concerned. I suggest that it could be the default functioning of the filter creation... ;
2) Be able to synchronize independently only a pair instead of systematically synchronize all the pairs. the comparison phase can be slow for some project, especially via network. Actually I have to remove all the pairs I don't want to synchronize to have one pair synchronized rapidly. Then I have to be careful to not save/erase the global configuration!
Best,
yuri
This already available. You can define Global Include and Exclude Filter settings (F7 or the big funnel-icon mid above the left-right pair definitions). These act as the "default" filter settings for each left-right pair but one can, on a per left-right pair basis, use Local Filter settings via the funnel icon in between each left-right pair.
2) instead, and likely simpler and less "risky" than your present approach, you can select multiple (saved) sync configurations to be run.
yuri
Thank you very much, I didn't know it was possible to synchronize multiple configurations at once.
It is certainly a better approch!
Best
