Hello, I've set up a sync for two different computers to a partitioned hard drive attached to one of the computers. I'm getting the email notification of sync from the computer that has the hard drive attached to it, but not from the other computer that is having a drive synced to a second partition on the first computer. What did I do wrong in setting up the second computer?
Mail Notification for two different machines
If you run the sync manually, does it actually finish, on the second computer? If not, FFS might be hanging/crashing. If it's fine, there is most likely a credential or settings error
Yes, it finishes manually and automatically. What would be the most obvious setting error? I'm just not seeing a difference between the two batch runs.
If there's an error sending the email, it will be in the log file.
