I've created a batch file to copy a bunch of folders from and old server to a new one and it works great when running manually but when I scheduled it as a task and run it, the task just keeps running and I can see the FreeFileSync.exe present in the taskmgr but not doing anything. The log file shows completed in 31 seconds.
If I run it back to back so there are no changes it should be quick as there is nothing to copy but the task shows running. My concern is that when it won't run at the scheduled time as it's already "running".
The OS is Server 2019 Standard.
ffs task doesn't end
