Donation Installation on Manjaro Linux
revan335
many Thanks for your work on the best Sync Program for my Backup and more.
How can i install the Donation Installation on Manjaro Linux?
The Free Edition is available on AUR and have a Auto Update/Installation through this without any expertise from a Installation of Packages on Manjaro/Arch Linux.
Many Thanks!
Greetings
Revan335
beuzbeuz78
@Zenju
I am in the same situation, I would like to use the Donation edition with my Manjaro Cinnamon edition.
How could we do ?
Best regards
Sebastien
revan335
@beuzbeuz78 and @all.
Do you find a Solution?
Many Thanks!
Revan335
revan335
Yes, the new Installer/Packet is the Solution.
Many Thanks!
Revan335
beuzbeuz78
@revan335
How do you proceed to download and install donation edition in Manjaro ?
Thanks in advance
revan335
Donate, than download and extract the Donation Edition, run the Installscript in this Archiv.
Same way by the Normal/Free Edition but no Donation Features there.
Thanks!
beuzbeuz78
Thanks, and for auto update ? does this work ?
revan335
i don't know. No new Version was available in this time.
beuzbeuz78
Ok Thank you very much.
phantomsfbw
Hi! I am running CachyOS and using your fantastic program to sync across a PC and two different TNS servers. Running 10Gb network so would like to take advantage of parallel operations, so a donation is in order. Before I proceed, would I de-install the current version, which was installed from the AUR repository e.g. 14.7 and then your establishment would provide #./install.sh version? Want to know what to expect, and thanks again for a really fantastic program.
