Remote execution of ff_batch file
Has anyone been able to run a ff_batch file form a remote computer? Either from a web page, rest API or just a local command on a windows workstation?
If you mean: running the FFS executable on a local machine using an FFS sync configuration saved in a *.ffs_batch-file stored on an (accessible) file server in the network: yes.
Thanks, issue solved.
