I have a Source on a PC that I'd like to backup to a Target on a Synology NAS.
I have the FreeFileSync Donation version.
I'd like to backup everything from the Source to the Target every hour or so.
If I delete something in the Source I'd like it to remain in the Target for 6 months, before it gets deleted for good.
Is this possible?
Many thanks.
Keeping 6 months of deleted files before permanent deletion?
You can use Versioning.
This will move all files to be deleted or replaced during an FFS sync to a specified location in its existing (sub)folder structure.
You can also Limit File Versions according to need. See the right-bottom part of the image in said manual section. This includes an option to delete versions after x days, where in your case x would be 183.
Thanks Plerry, I'm working my way through versioning at the moment, I'll report back once I've tested it thoroughly.
