Can I designate where sync.ffs_db are kept
phrab
I have 2 machines (different systems) & want to do 2 way synchronization on some files that are on each machines desktop. I can do this with 2-way synchronization, but it always creates a sync.ffs_db on the desktop. I would like to have control over where they are kept.
Is this possible?
Thanks in advance.
phrab
Thank you for your quick explanation. I appreciate your time and expertise!
mditsch
could it maybe instead created with the hidden flag when created during sync?
phrab
could it maybe instead created with the hidden flag when created during sync? mditsch, 29 Nov 2020, 10:28
It is created with the hidden flag. However, I have my folder options set to see hidden files. From the reply above, I'm satisfied that the file must be created in the source & target folders.
mditsch
are you really sure for the hidden flag because I have do to set this file always manually to hidden?
phrab
Yes. And I didn't modify any of the Tools/Options.
phrab
mditsch
strange
