List of past sessions
kdaej
On the configurtaion panel I usually have the last session and the list of previous sessions with the name of the *.ffs_gui files and the number of days since they were last used.
I no longer have this list but only the [Last session]. Why ? How can I fix that ?
There us only one previous session that it shows. Everything under "last session" will be sync configuration files that you have saved as an independent job, or a batch job. If you know where your saved jobs were stored, you can open them in FFS and they will display in that list again. They may have been hidden from FFS or deleted accidentally.
