Today I run into a problem of GTK 2 dark theme on Plasma KDE 5.20.4 and after reporting the bug I got replied that GTK2 is deprecated and the app developer should upgrade their GTK library to 3 or 4. So why GTK2 is still used by FreeFileSync if it's dead ?
Operating System: Manjaro Linux
KDE Plasma Version: 5.20.4
KDE Frameworks Version: 5.76.0
Qt Version: 5.15.2
Kernel Version: 5.4.80-2-MANJARO
OS Type: 64-bit
Why still depending on deprecated GTK2
I know updating to new GUI library is time consuming, but for now I think the transition should be done because GTK2 is no longer maintained for many years and most Linux distributions will remove support for it, so the app will face some serious problems concerning building, running and compatibility with themes.
No, the issue as explained in the link is not time at all.
I have been compiling FreeFileSync for Devuan and Fedora with GTK3 for a few months now, and I've had success. I'm very loose with my requirements for what widgets look like though, but I don't think that FreeFileSync looks sloppy with gtk3.
GTK3, unlike GTK2, fails to properly update control sizes after a layout change (e.g. different font size). (Tested on CentOS 7). As a consequence all kinds of texts will be cut off (or sometimes not: GTK3's layout updating seems unpredictable).
I worked with Java and C# and they both have layout managers/containers to manage GUI components and change their sizes according to parent containers properties and type. I don't think that GTK3 doesn't have this kind of components ?
GTK+ 3.5.1 is most likely the culprit:
https://github.com/GNOME/gtk/blob/e2afb59a0b84b13c59216379b10e08c43398d82f/NEWS#L7798
GTK layouts are updated only for *visible* windows. This means the common idiom of creating a window hidden, arranging its elements, and then showing it all at once is broken with GTK >= 3.5.Theming:
- Optimizations to style invalidation
Well, most users have very low opinions of the GTK team. Maybe for fun you could implement FreeFileSync in QT?! I'm sure that's a ton of work though.
I know this is an old thread, but now that I'm going to compile it for Gentoo, I wanted to check if there is any update on this matter?
FreeFileSync 11.0 introduced support for GTK+3 per the Archive page.
The discussion about manual compilation from source links to various build recipes that make references to which version of GTK+ they use to compile the application.
On that note, Zenju, please don't migrate to GTK 4 or 40 or whatever they call it now!
I should have worded that differently. It sounds as if GTK3 was supported by FFS, but it's not. This were merely first steps towards a support.Start supporting GTK3
Last time I checked all dialog layouts with GTK3 were broken and there was no apparent way with wxWidgets to fix them.
In general FFS will always follow wxWidgets with regards to the GUI framework, and GTK2 is still the latest GTK version there that is not broken.
Wow, I thought wxWidgets 3.2 dropped gtk2. At least the Debian package suggests that they only bother to compile wxWidgets 3.2 against gtk3.
$ dpkg -l | grep wx | grep 3
ii libwxbase3.0-0v5:amd64 3.0.5.1+dfsg-5 amd64 wxBase library (runtime) - non-GUI support classes of wxWidgets toolkit
ii libwxbase3.2-0:amd64 3.2.1+dfsg-1 amd64 wxBase library (runtime) - non-GUI support classes of wxWidgets toolkit
ii libwxgtk3.0-gtk3-0v5:amd64 3.0.5.1+dfsg-5 amd64 wxWidgets Cross-platform C++ GUI toolkit (GTK 3 runtime)
ii libwxgtk3.2-0:amd64 3.2.1+dfsg-1 amd64 wxWidgets Cross-platform C++ GUI toolkit (GTK 3 runtime)
ii libwxgtk3.2-dev:amd64 3.2.1+dfsg-1 amd64 wxWidgets Cross-platform C++ GUI toolkit (GTK 3 development)
ii wx-common 3.2.1+dfsg-1 amd64 wxWidgets Cross-platform C++ GUI toolkit (common support files)
ii wx3.2-headers 3.2.1+dfsg-1 all wxWidgets Cross-platform C++ GUI toolkit (header files)
