Schedule Batch Jobs with MacOS
uwenet
First of all....
After using FreeFileSync for some days I immediately donated because for me it is by far the best Backup Solution I found - Thank you!!!
I want to use the Schedule Batch Jobs with MacOS.
It seems to work fine with Automator and Calendar but I have one Problem!
Every time after my Computer wakes up after Standby the Backup Batch Job starts.... Why??
I configured it daily but at the evening, and now it starts also after every Standby.
Perhaps there are other ways to configure batch jobs with a Mac (Catalina)?
Thank you
Uwe
uwenet
SOLVED!!!
After a little bit of research...
you can do it with cron under Mac or Linux:
open terminal:
crontab -e
00 18 * * *    /Applications/FreeFileSync.app/Contents/MacOS/FreeFileSync /PATH/TO/backup.ffs_batch
With this example it starts at 18:00 every day (and NO start after Standby!!!!)
Using Cron under MacOs:
https://medium.com/better-programming/https-medium-com-ratik96-scheduling-jobs-with-crontab-on-macos-add5a8b26c30
