OLEVERB error on copy files to phone
daveme88
I connected my android phone via usb and select a target directory there (mtp:\....)
When I try to sync I get:
Error code 0x80040000: Invalid OLEVERB structure [IPortableDeviceProperties::SetValues]
If I copy the same file manually (drag and drop in Windows file explorer), it copies fine
What's going on?
How does it function after updating?
daveme88
Still not working
Windows 10? Other issues from the web point to Windows corruption as the main cause. Any updates you can do? Repair install of Windows?
daveme88
Yes, windows 10.
I can try it from my laptop which is also windows 10 - if that works it points to some setup on my pc
I would try that. What phone do you have?
daveme88
Oneplus Nord N100 - and I am trying to write to the SD card
What about local phone storage? I would run:
sfc /scannow
dism /online /cleanup-image /restorehealth
sfc /scannow
in an admin command prompt. Yes, sfc twice, before and after dism. Others with the same issue seems to resolve it by fixing OS corruption. A repair install to Windows may be in order
