Hello - I looked in the docs and Q&A but could not find this answer. After doing an Update Synchronization, I would like to see a list of all the files that were copied or updated. How do I do that?
Thanks,
Tony
Display Changed Files?
Before your actual sync, you can look in the Compare result window.
After the sync, you can check the log-file. F4 or the icon left below the Compare result Window.
