Windows 10 & iSCSI
gregkoss
This is a great tool. And this is not a showstopper since I can 'Ignore" my way to working correctly.
I get these two attached messages when doing a compare on my Windows 10 iSCSI drive. Any thoughts on how to make them go away?
The first message looking for V:\Brock_Rides is a valid directory on the V: drive.
I don't have a directory called V:\found.000 from the second message.
Otherwise I have full R/W permissions on this drive and everything works perfectly if I click the Ignore button and continue on.
Thanks for listening.
-G
The first error is probably caused by a drive that needs a chkdsk ran on it. It probably needs chkdsk for a reason though, either it wasn't unmounted correctly or it is failing, test it. The second error may be mitigated by running as admin, although the found.xxx folders are caused by chkdsk finding broken files or fragments.
