Hi
How I can control or start sync via OSC protocol or under protocol.
I want to start a sync with under software.
osc
Could you write a batch file that calls FreeFileSync with the right flags and parameters, and then configure your operating system to run that batch file based on an OSC signal?
I use a software called Touchdesigner.
The software recording me video files, when it finish i want to send a command from her to FFS to sync.
I can write anything.
The question is if the FFS knows to receive external commands, if there is another way?
for example to run the FFC and that finishes synchronization will close itself, and next time I will need to send a command to run the FFS again. Thank you
Yes, you can call the FFS executable with the ffs_batch file as the parameter
