Win10 Task Scheduler
New User, win10 (latest version) task scheduler never completes. The FFS log file shows job as complete however the task scheduler job continues to show as running. Even if I set the job to end after 1 hour.
Still having issues?
I have the same issue, I configure the windows Task Schedules exactly as per the batch schedule tutorial video, I set it to every 5 minutes, if I test and run it manually it works perfectly fine but the task itself never runs,
Also the status is permanently "in execution" even if I set the batch to close after running
EDIT: After searching some troubleshooting of task scheduler and running some fixes and then restarting the computer the task scheduler has started working as expected!
Fixed in the next version: viewtopic.php?t=8535#p39347
