Synchronisation is perfect - in very good time.
But: if I delete files in my specified folders(left) - then synchronise - but in the folders(right), the deleted finles are not deleted - where can I specify, that the files will be deleted?
Deleted files
Select the 'mirror' option in settings. Sounds like you have 'update' selected
Thanks a lot, it was as you suggested. Now it works! Great!
