Right click doesn't give options when both files changed
phrab
I just upgraded to version 11.5. In the past, I compared certain files (or even 1 file) in 2 folders. When both files had changed (even though I knew 1 was current), I could right click on the red icon, & change it to copy 1 way or the other. This meant that I could override the 2 way synchronization without changing the default.
With 11.5, there are 2 problems. 1) There doesn't seem to be a way to copy from the right pane to the left. 2) If I change the synchronization at the top right of the screen, it wants to change the default (the 2 way synchronization).
Is there an option to have it work as it did before?
If not, can I go back to the previous version?
Thank you in advance!
You don't right-click anymore, but you can hover over that red lightning bolt and you can choose from three options, copy right to left, left to right, or do nothing. Moving the cursor left and right in that little box will display those options
phrab
Thank you so much!! I never thought to move the mouse...duh. This deserves another donation!
