Hoi to all,
my position is the poor guy must help his wife to run her business.
So far she uses different workstation and pc's and i would have collect all the files in one place.
Therefore this is the best software I found.
My question is:
I would like if there are files with identically names on different sources (and there will...) not only to overwrite the existing one but instead have a copy on the target with a timestamp or any other file extension may be to see them historically:
billing_to_company1_20201203_141210.txt (created on a pc)
billing_to_company1_20201204.141911.txt (created on any laptop)
and so on.
Does anyone have any idea ?
I didt find it as a standard possibility in the tutorials.
Thanks in advance.
Bernd
P.S.
The target is a USB-external-disk were I can't use any windows functionallity.
Keep versions of backuped files
(Not quite sure I'm understanding what you're wanting, but...)
In the Synchronization settings (F8), you can set up, Versioning (& versioning method, like with timestamps).
Hoi therube,
I found at least how to memorize deleted files.
I will check your additional idea and thank you in advance.
How was the choke: If you (means me) dont find your solution, "rtfm".
I think you know what this mean.
Cheers
Bernd
Cheers
Bernd
