11.5 Bug - Warning in session list retained after good sync
GFG
After a sync which has the warning of significant differences between the comparison folders, and completes with the status of "Completed with warnings", a subsequent sync will retain the yellow warning symbol in the session status list, even if 100% successful with no warnings. Removing the warning logs has no effect.
If you mouse-hover of the warning it will redirect to the last sync log (which seems to contain a warning message).
GFG
Yes, it does, and it works, but it never clears, even if I remove the files in that folder.
The status should be overwritten after the next sync (not just comparison)
